shahram's Avatar
XDI2 + 3.6 + PMO Carbs
I am trying to figure out a good set up for the ignition advance for my new engine.
A 3.6 twin plug with PMO carbs and XDI2 ignition.
Any of you with a similar set up? I will run the engine on a dyno next Friday but would like to have a fairly good map for the start of the tuning process.
So far I think I would go with 10 for 1000, up to 30 for 3000 and back to 28 by 4000 and up.
What do you guys think?
Old 08-19-2012, 10:05 AM
Chain fence eating turbo
What's your compression ratio and cams/cam timing?
Old 08-19-2012, 12:45 PM
shahram's Avatar
for now stock 964 cams and compretion ratio.
964 Cams are 470"/430" as far as I know and compression 11.3:1.
Will change the cams to 490"/470" one day when I have to open the engine and maybe go with a different aftermarket piston profile..
Old 08-19-2012, 01:01 PM
What octane fuel will you be using?
Did you incorporate knock sensing into your XD12 installation?
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-19-2012, 02:08 PM
shahram's Avatar
yes Steve, the knock sensor is connected to XDI2 but not activated in the wintec software.
I use only 95 and up. actually only 98 Octane.
Old 08-19-2012, 02:11 PM
Well, I guess since you are going to tune on a dyno, maybe back out the timing a little over you initial numbers to play it safe.
You're going to get optimal numbers anyways once tuning so if it's too retatrded, at least it's safe.
Old 08-20-2012, 07:20 AM
