privatepang's Avatar
on road trip and need some CIS help/ideas
Hey guys so im on a 3 week road trip down from vancouver yo san diego via hwy 101. currently in eureka in cali and car has started stuttering as if its fuel starved. its a 75 911s with a stock cis 2.7. this has happened randomly through out the trip but its happening quite often now. doesnt stutter when im revving it in neutral , mainly in 4th 5th around the 3k revs mark and above up to this point when its happened its usually because my heater hoses have popped off and its usually resolved when i put them back in. i topped up my gas thinking it was bad fuel but this hasnt fixed it. latest thing was to reseat the airbox as it was slightly off. feels like a vacuum leak issue but nothing a pparent is loose... i didnt brong carb cleaner but was hoping you guys may have other things i could try to troubleshootthis. sorry im wrting this from my phone and theres limited reception. thx in advancr
1975 Aubergine 911S - Barney
"When that doesn't work, and it doesn't quite often, it's as though your face has been amputated." - Jeremy Clarkson
Old 08-14-2012, 12:10 PM
O and driving around town at slow speed is fine. only hgihway speeds...
Old 08-14-2012, 12:28 PM
porwolf's Avatar
I am no expert on CIS but have one on my 79 SC. No problems with it here. But I am reading about possible problems in the future. From what I read here a quick way to possibly find a vacuum leak is to spray cold starting fluid around all suspect areas. If a vacuum leak area is sprayed the reving should increase. You should be able to find that cold starting spay can in any auto parts supply store. Also from the olden days I remember, after checking the spark plugs the spark itself should be checked by removing the spark plug connector, one cylinder at a time and see whether there is a spark hitting the engine metal. Hold the spark plug with a dry towel or you get zapped.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 08-14-2012, 12:29 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I just found a thread in the 930 section where the voltage regulator - above 3000 - would send excess (18 volts) voltage to the CD box and create problems. Have not read of this before but if your lights get brighter as the rpms go up, may be worth looking into.
Old 08-14-2012, 12:35 PM
Thanks for the tips so far. ill be hitting san fran in 2 days hopefully. anyone know a reasonably pticed shop tot ake ablook at my porker if it comes down to it ?
Old 08-14-2012, 12:38 PM
Get a meter and it ll tell you in minutes.
Bruce
Old 08-14-2012, 12:52 PM
Porchcar guy's Avatar
Have you considered the fuel filter ? If it older than a year, should be changed. A long trip may have broken loose junk in the tank and the filter is your friend. As the engine calls for more gas, if the filter is clogged, it cannot deliver the fuel needed. may not be what is going on but it is a simple fix. Carb/ Injector cleaner could help also and readily available. Good Luck !!
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 08-14-2012, 12:54 PM
na2ub's Avatar
The last time I had some stuttering, I changed the plugs, fuel filter, and dist. cap and rotor. Don't know which one was the problem, but the problem went away. Just give it some fresh bits, which it probably needs anyway.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 08-14-2012, 01:03 PM
Thanks guys. Hopefuly Napa Autoparts has the fuel filter in stock!
Old 08-14-2012, 01:18 PM
porwolf's Avatar
And don't forget to get new crush washers if you get a new fuel filter. Had to do that after connecting a new fuel filter on my 79 SC and noticed a leak with the old washers.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 08-14-2012, 01:34 PM
If you cross over the 80 bridge there is a good guy in Crockett under the end of the bridge!
His name is Pete, he did some work on my SC motor and has a 5 star rating on Yelp!
1315 Wanda St
Crockett, CA 94525
510-787-3301
Old 08-14-2012, 01:41 PM
PP part number Bosch 0 450 905 016 ...found it at other sites..all around $13.00
Bosch 0 450 905 016....NAPA AUTO PARTS
Auto Parts of Eureka
90 West 5th Street
Eureka, CA 95501
(707) 442 - 1786
15 year PCA member
Old 08-14-2012, 02:11 PM
Bob Kontak's Avatar
90 West 5th Street
Eureka, CA 95501
(707) 442 - 1786
Nice work.
Call ahead if it takes a day to get it in stock.
Old 08-14-2012, 02:24 PM
Thanks for the recommendations. The stuttering has gotten worse as trying to push for willits. so going to try find someone in santa rosa to check it out tomorrow. as Napa Autoparts in Garberville didnt hv the fuel filter in stock. Appreciate the part number!
Old 08-14-2012, 03:43 PM
cpa cpa is online now
If your still in Willits or further down 101 try to find a shop that is familiar with volkswagon. Have them pull each spark plug wire until they find which one is causing the miss. Pull the injector and clean it under pressure until you get a good spray pattern. You can get the rest of them cleaned when you return home.
cpa
Old 08-14-2012, 04:01 PM
Wow thanks for all the replies guys. Well car started backfiring pretty badly 10 miles from Willits Pulled over and tapped the fuel filter (gently) to see if the idle would change and it did so I think that could be teh reason. Need to find somewhere to change it over for me or try it myself. I have the 101 book and just worried if I attempt it myself might do more damage and screw up the rest of my trip.
was meant to do santa rosa and then fairfield for napa region but now might have to go straight to san fran if i can't find somewhere to do the change.
I actually have 2 spare injectors with me. I had them all cleaned approximately 7 months ago so I could potentially pull them and see if the spray pattern is right. Do I just have to pull it out by force or is there a bolt I have to undo?
Other issue that has developed is my rev meter is going crazy now... argh.. been running well up to now but i guess its to be expected on a long journey...
thanks for all the help again guys. If there are any pelicanites around that are free to help, I'll supply a 6 pack of ice cold beers
Old 08-14-2012, 04:30 PM
ROW '78 911 Targa
timmy2's Avatar
Tach trouble, missing above 3k, could be alternator or voltage regulator failing or loose fan belt. Change the fuel filter for sure, maybe other stuff will go away.
Good luck.
Old 08-14-2012, 04:51 PM
dyusem's Avatar
You may want to call Peter Wilms (M: 415-948-8189, O: 415-453-3501) in San Rafael which is on your way to SF.
Peter works on my '80SC and is a factory trained mechanic, a straight-shooter and knows CIS like the back of his (large) hands.
If you need any assistance in Marin, just PM me.
Good luck,
Old 08-14-2012, 05:10 PM
Ok found a guy through the forums. Dave Merz. Hes pretty busy but said he'll try and fit me in... fingers crossed. Gotta make Monterey on the 19th and really wanna see Napa valley so hopefully it isnt a complicated fix...
Old 08-14-2012, 05:35 PM
