Help me identify this part in engine compartment?
911 newbie here... Recently purchased a 1982 911 SC and am trying to learn everything I can about it.
What is this? No vacuum line currently attached??
Old 08-20-2012, 10:19 PM
RETIRED
Joe Bob's Avatar
I think decell valve....
2012 ML350 3.0 Turbo Diesel
Old 08-20-2012, 10:34 PM
Thanks... Didn't know about the decell valve, but just read a few threads on it.
As seen in the picture, no vacuum line is connected to my decell valve. I presume the previous owner disconnected it intentionally.
  • Where does the feed vacuum line come from so I can ensure it is properly capped? or reconnect it?
  • Is simply removing the vacuum line (and capping it) functionally the same as removing the entire valve, other than the cosmetic advantage of cleaning up the engine compartment?
  • Lot of discussion regarding its value and function on turbo motors. Whats the general consensus on the 3.0 SC? Leave it or pull it?
Old 08-21-2012, 04:45 PM
