-   -   Replacing omega spring -- other parts needed? (http://forums.pelicanparts.com/porsche-911-technical-forum/697436-replacing-omega-spring-other-parts-needed.html)
rwilner 08-21-2012 06:27 PM
If you replace the clutch helper / omega spring, is it also a good idea to replace the bearings, shaft, spacers, end cap, etc. associated with the spring, or can you reuse the existing stuff and just replace the spring?
Cooper911SC 08-21-2012 07:23 PM
Just re-use existing without a problem. I've done 2 Omegas on my SC on the last 150K.
One right after I got the car (at 178K) and another around 250K.
