-   -   Front end squeaking like a whorehouse mattress (http://forums.pelicanparts.com/porsche-911-technical-forum/697666-front-end-squeaking-like-whorehouse-mattress.html)
schwaggen 08-22-2012 11:50 AM
After a panic stop to avoid running over a wild peacock in my neighborhood, my front end has developed an annoying squiggly squeak over every ripple in the pavement. I'm guessing bushings, but which ones?
schumicat 08-22-2012 12:04 PM
sway bar bushing is one possibility. spray silicone lube on them and see if it makes noise go away to check.
RWebb 08-22-2012 01:09 PM
when were the A-arm bushings replaced? and with what?
SilberUrS6 08-22-2012 02:27 PM
I enjoyed your title simile. Actual experience? ;)
kidrock 08-22-2012 07:27 PM
check to see if all your bushings are hotter than a whore's ass on Nickel Night.
Chuck.H 08-23-2012 05:58 AM
I'm actually surprised by the comments -- one of the first pieces of advice I got off the 'porsche list' 10+ years ago was the source of a very common front end squeak. The bushings and torsion bar adjusters wear and then the torsion bars rub against the tubes inside the a-arms. I was skeptical but it was exactly my squeak.
Do a search and see what comes up with say 'torsion bars rubbing squeak'...
Chuck.H
'89 TurboLookTarga, 338k miles
scottb 08-23-2012 06:58 AM
I had a front-end squeak and replaced the torsion bars with good used ones. Problem solved.
ivangene 08-23-2012 06:59 AM
NOTE: running over peacocks might be the easy/cheap way around this
+1 for Chucks's point - if it was sudden, something moved, and sway bar bushings usually dont start suddenly
RoninLB 08-23-2012 10:31 AM
maybe post a few pictures of the rear t-bar bushing at the t-bar adjustment
the car should be laying flat carrying full weight of the car without having been jacked off. oops.. Jacked up
how many miles on the car?
has t-bar bushings ever been replaced before?
