schwaggen's Avatar
Front end squeaking like a whorehouse mattress
After a panic stop to avoid running over a wild peacock in my neighborhood, my front end has developed an annoying squiggly squeak over every ripple in the pavement. I'm guessing bushings, but which ones?
Old 08-22-2012, 11:50 AM
schumicat's Avatar
sway bar bushing is one possibility. spray silicone lube on them and see if it makes noise go away to check.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 08-22-2012, 12:04 PM
AutoBahned
RWebb's Avatar
when were the A-arm bushings replaced? and with what?
Old 08-22-2012, 01:09 PM
Banned
I enjoyed your title simile. Actual experience?
Old 08-22-2012, 02:27 PM
muck-raker
kidrock's Avatar
check to see if all your bushings are hotter than a whore's ass on Nickel Night.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 08-22-2012, 07:27 PM
I'm actually surprised by the comments -- one of the first pieces of advice I got off the 'porsche list' 10+ years ago was the source of a very common front end squeak. The bushings and torsion bar adjusters wear and then the torsion bars rub against the tubes inside the a-arms. I was skeptical but it was exactly my squeak.
Do a search and see what comes up with say 'torsion bars rubbing squeak'...
Chuck.H
'89 TurboLookTarga, 338k miles
Old 08-23-2012, 05:58 AM
scottb's Avatar
I had a front-end squeak and replaced the torsion bars with good used ones. Problem solved.
1984 Targa
Old 08-23-2012, 06:58 AM
ivangene's Avatar
NOTE: running over peacocks might be the easy/cheap way around this
+1 for Chucks's point - if it was sudden, something moved, and sway bar bushings usually dont start suddenly
Ed M
86' Coupe
Old 08-23-2012, 06:59 AM
maybe post a few pictures of the rear t-bar bushing at the t-bar adjustment
the car should be laying flat carrying full weight of the car without having been jacked off. oops.. Jacked up
how many miles on the car?
has t-bar bushings ever been replaced before?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-23-2012, 10:31 AM
