How does one separate the black grille from the rear spoiler on a 964
Hello all,
I was wondering if anyone out there knows how one separates the black grille from the rear spoiler on a 964.
Thanks.
Dino
Old 07-04-2012, 04:50 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
It's glued on.
Old 07-04-2012, 10:12 PM
Senior Advisor
James Brown's Avatar
I removed mine, it is glued on with some sitka flex type stuff, get it at a boating supply store. comes in a calking gun.
08 Cayenne Turbo
Old 07-04-2012, 10:14 PM
Hi James,
How did you manage to remove the grille?
Old 08-24-2012, 01:36 PM
As stated it's glued on, remove at your own risk! You can break the spoiler.
Old 08-24-2012, 05:41 PM
RETIRED
Joe Bob's Avatar
Probably with a heat gun....
2012 ML350 3.0 Turbo Diesel
Old 08-24-2012, 05:50 PM
Senior Advisor
i started at one corner and slowly pulled the plastic spoiler from the base. pull and hold, it will slowly start to come apart (good adhesive) go to the other corner and repeat till it pulls free, try not to break the spoiler but if you do, i have a spare. ($$$$$)
08 Cayenne Turbo
Old 08-24-2012, 09:28 PM
Thanks guys. I'll try not to break it!
Old 08-25-2012, 02:18 AM
