Send a message via AIM to JimDog
which wheels will fit my '71 911T?
My '71 911T came with 15x5.5 fuchs, however, I'm pretty sure that it originally had 16" wheels on it, because the speedometer reads somewhat faster than I'm actually going.
I've seen several sets of fuchs for sale with 16x6 fronts and 16x7 rears. Will these fit on my car without hitting the fenders?
-j
Old 05-26-2002, 12:22 PM
Administrator
Jack Olsen's Avatar
I don't believe 16-inch Fuchs were available in 1973, and Porsche speedometers are notoriously inaccurate.
However, 6x7x16 wheels should fit with up to 205's all around. Some guys get 225's to fit in back, but that may require some rolling of the inner fender lip.
Old 05-26-2002, 12:58 PM
pjv911's Avatar
Send a message via AIM to pjv911
Thats what I have 16x6x7"on my 69` which by the way your car did not come with 16" . My rear tires 225/50/16 did rub a little on the inner lip until I adjusted the rear camber more negative and replaced the rear torsion bars with 28mm hollows. No more rubbing now. Also note that every tire brand has variances in the actual width even though the #`s are the same. So which tires you choose will make or break the fit. Front tires 205/55/16 dont rub at all.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 05-26-2002, 01:03 PM
New kid in town
71T Targa's Avatar
The 7's may or may not fit even with the 205's all around. I just did this, and needed to adjust the rear camber as well as roll the fenders.
Good luck.
I wish I still had 9111113443...
Old 05-26-2002, 01:07 PM
Hi Kurt,
Just curious, can you spin those 205's on take off?
Old 05-26-2002, 01:08 PM
pjv911's Avatar
It will smoke 1st gear with the 225`s(not 205`s) without much effert, even on a roll.
Old 05-26-2002, 05:35 PM
Cool Kurt.
Can you give me a brief or long (if you are wiilling) description of your engine.
Regards, Fritzer
Old 05-26-2002, 07:47 PM
CraigD's Avatar
JimDog,
Tire size will affect the speedo reading. I believe the car originally came with 185/(70 or 72)-15. If you go to Interactive Tire Size at Early S Technical Data you can put in various tire sizes and see how they affect the speedo reading.
You can also use the gearing charts at Dr Timmins Instant G to calculate the effects of different tire sizes on various aspects such as MPH, RPM at xMPH etc.
I am using 205/60-15 on my 71 911T causing the speedo to read about 3% faster than actual road speed.
Craig Dinger
'02 Sampson Titanium, Campagnolo 20 speed roadbike, daily commuter, 3,700 miles and counting
'71 911 T Targa for fun
'89 BMW 325i sedan wife' ride
'83 BMW 533i White/Cardinal red leather, Wet weather commuter
'89 BMW 535i auto to 5 speed conversion in progress
'98 Ford F-150 weekend hauler
Old 05-28-2002, 10:25 AM
pjv911's Avatar
Fritz its just a fresh stock 2.7 with SSI exhangers and good state of tune . Here`s some pictures of the tire clearance (225/50/16) and motor.
Old 05-28-2002, 03:37 PM
