Camshaft Upgrade for 83 SC
I've been searching the forums for the best camshaft options for my 83SC. But everything I'm find mostly is for the earlier lower compression engines.
If I assume I am not going to change C/R (currently 9.3:1) and I have SSI's, and the car is mostly used for street, so I don't want low end performance to suffer. If anything, I'd like it to get better. What would be the recommendation? Elgin 330/DC-15 (which are pretty much the same) 964 or DC-19 I'm not even entertaining 20/21's due to the price.
Matt. 83 911SC 85.5 944 NA - Sold |
Matt,
If maintaining low-end performance is your main priority, I would not change cams. All that does is shift the powerband UP to varying degrees, depending on profile. Save your money and have your distributor recurved for improved throttle response.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
My engine is similar to yours with 9.3:1 CR, small ports and SSIs. I chose to go with DC13 cams which are a higher lift SC cams and lighter flywheel. I did this because I wanted slightly more character but didn't want to loose too much low end and didn't believe it wise to go with higher rpm cams with the small ports.
Today I drove my friends stock 1980SC that I know well as well as my own and I believe maybe the light flywheel wasn't a good idea. It is more responsive when 'racing' , but i have lost a lot of that low end grunt. I'd very likely go with the same cams again but stayed with stock flywheel
80SC (ex California) |
Air Medal or two
Thought the 964 was the Deal !
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Just bringing this old thread back. I'm finally close to my engine rebuild (or maybe more of a refresh...we'll see). After some more research I'm leaning against using the 964 cams due to concern for low end power. Car is just a street car. Any more thoughts on this?
This and adjust the cam timing to the upper limit of the advanced range of the SC cams as per specs.
1973 Porsche 911 RS 1981 Porsche 931 Euro-Intercooled-GT 1984 Porsche 911 Euro Carrera widebody 1987 Porsche 924s Rallye Spec Instagram: @soyracer |
I'm very interested in doing this to my RoW. Would like to change the final drive to something a little steeper at the same time
83 RoW Cab. Send a message if you're here on Oahu. ![]() |
Not sure what Web is charging these days but did 20/21's on my 83 Targa about 15 years ago and the car was a blast.
Coupled with SSi's the motor was great around town and the cams really started making power 3200 rpm & up......pulled strong through 6k+
HankP 1976S Targa BMW R100RT&RS&R75/5&6 Horizontally Apposed |
