-   -   Which CV boot do I need? (http://forums.pelicanparts.com/porsche-911-technical-forum/699023-cv-boot-do-i-need.html)
awdbandito 08-26-2012 11:50 AM
Which CV boot kit do I need?
This is for a '75 911S with a build date of 5/75. I'm not sure which boot I need.
Here are some pictures of the offending CV joint.
http://i213.photobucket.com/albums/c...3/DSCN4124.jpg
http://i213.photobucket.com/albums/c...3/DSCN4125.jpg
I just want the boot, grease, and clamps.
Thanks,
plymouthcolt 08-26-2012 12:27 PM
Here Porsche 911 & Carrera Axles & Bearings - Page 1
Flat6pac 08-26-2012 12:27 PM
using 4 10mm cap bolts uses 901.332.293.12 plus the bands to hold them in place
Bruce
Flat6pac 08-26-2012 12:28 PM
Pelican has the whole kit containing everything..very convenient.
Bruce
michael lang 08-27-2012 12:43 AM
But if you are going to go through the trouble of taking the axle shaft out to replace the one boot, you might as well do the whole axle shaft. I would just suggest to be super careful to keep the bearing assemblies intact or you could have more problems then what you started with.
awdbandito 08-27-2012 06:01 AM
It looks like I have more than four bolts on the interior of the hub. Is this what you are calling a cap bolt?
Bruce
I have done many axle changes and boot replacements on other cars, but never the 911. I feel like I can do it without causing damage. I'm just trying to figure out what part I need. I don't know what I am looking for.
Thanks,
luskesq 08-27-2012 08:53 AM
If you have 6 cap bolts they are likely M8 x 50 mm. In '75 there was a mid-year change with the Cv's so I'd call our host to see which one you need.
Keith
