Which CV boot do I need?
Which CV boot kit do I need?
This is for a '75 911S with a build date of 5/75. I'm not sure which boot I need. Here are some pictures of the offending CV joint. ![]() ![]() I just want the boot, grease, and clamps. Thanks,
'12 Cayman R 77 C3, 85 Carrera, 75 911S, 88 Carrera, 96 Carrera, '65 912, '06 Cayman S - Gone |
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) |
using 4 10mm cap bolts uses 901.332.293.12 plus the bands to hold them in place
Bruce |
Pelican has the whole kit containing everything..very convenient.
Bruce |
But if you are going to go through the trouble of taking the axle shaft out to replace the one boot, you might as well do the whole axle shaft. I would just suggest to be super careful to keep the bearing assemblies intact or you could have more problems then what you started with.
Mike '89 CARRERA #402 |
It looks like I have more than four bolts on the interior of the hub. Is this what you are calling a cap bolt?
Thanks,
If you have 6 cap bolts they are likely M8 x 50 mm. In '75 there was a mid-year change with the Cv's so I'd call our host to see which one you need.
Keith |
