Dept store Quartermaster
lendaddy's Avatar
The engine is almost out. Please answer these questions.
I am a couple hours or less from driopping the motor and have hit a bit of a roadblock. Here are the remaing issues.
1. What are the wrench sizes to the oil cooler hard line? They are over 25mm I know that but I need to know what two wremches to buy.
2. The only wires I removed from the tranny were on the passenger side and there were two wires in one connector. Is this for both the reverse backup and speedo? I dont see anymore?
3. The hex head bolts (8mm) on the CV joint couplers are incredibly tight. Any tricks here? I feel like I am gonna strip the heads before they break loose, or worse yet pull the car off the jack stands!
4. How high do I have to jack this thing up? I have it as High as my stands will go on the torsion tubes . Do I have to put spacers under those? I think I will need 4-6 more inches to pull the motor out. (yes the bumper is off)
5. What is the balance point for the motor and tranny together? I assume well behind the sump but?
Thanks again guys.
Cornpoppin' Pony Soldier
Old 05-29-2002, 06:25 AM
Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
Re: The engine is almost out. Please answer these questions.
All we can do is help you were we can!
Are you taking pictures of all this? Let us know how long it takes to drop the engine BTW...it sure sounds like a nightmare, is it?
Use degreaser to totally degrease the outside of the boot where the bolt heads are. If you have to use a small screw driver to dig out anything else in their heads, do so. Fit must be tight, and pack em in. For the right inner and left outer, stick the wrench in the head, get behind the car and push with the bottom of your foot.
Rotate the wheels so that each head is on the bottom and do them a bolt at a time that way. That's how I did it, and it took a long f'ing time.
For the other two joints, get behind and just pull like crazy and they'll come loose.
-kb-
Old 05-29-2002, 06:41 AM
lendaddy's Avatar
Na, It's not that bad. I probably have 3-4 hours of work into it so far and with just a couple to go I'm pretty happy. Especially since I've had no help thus far. I spend alot of time sitting and studying things with a beer in hand you know. I have a tv in the garage so I use it as time to wind down from work. Get home at 7-8 and work in the garage till 12 or 1 am it's actually quite relaxing.
Old 05-29-2002, 06:55 AM
brandett's Avatar
1. Hard oil line is 30 and 36 mm, working on mine right now. Its a tough one.. You need long wrenches and patience. Search the forum on hard oil line for more info.
It΄s my hobby.
911 SC -82 coupe.
My Project
Old 05-29-2002, 06:58 AM
Be sure, on the cv-joint hexheads, to thoroughly clean out the hex recesses. spray 'em with carb cleaner or something. You need to get the wrench into those recesses as far and firmly as possible, and they tend to pick up a jot of junk.
When I last took my engine out, I hoisted the rear end rather than jacking it--used a blanket as padding, heavy rope and then a good comealong hooked to a joist in the barn.
To see where the engine/trans CG is, look for the padeye used for single-point lifting of the engine, attached to one of the small case-separation-line throughbolts near the front (transmission end) of the engine. That's the CG.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 05-29-2002, 07:17 AM
John Brandt's Avatar
Those M8s come out in a jiffy if you have a long extension or combine several smaller ones onto your ratchet with 6mm hex socket to clear the car's body. Then you can use a cheater bar and get some leverage
Lendady, have a bucket ready when you undo that big oilline!
Old 05-29-2002, 07:18 AM
lendaddy's Avatar
Yep, did the carb cleaner thing last night, Also degreased the underside of the tranny and mounting area. Plenty of time for her to dry till tonight. I also thought about extensions and a ratchet. I think I will try that. any ideas on my other questions?
Old 05-29-2002, 07:25 AM
Senior Member
Superman's Avatar
Get the CV fasteners clean and be sure the tool is seated. I use two or three long extensions so that I can get plenty of force on it.
CG is between the tranny and the sump. It is roughly where the #3 cylinder is. Just forward (toward the front of the car) of the sump plate. Lowering the engine is where you really should make sure you have a little help. This is going to be something around 600 lbs you will be balancing on the tip of a floor jack.
You're best off with the set of four oil line wrenches for your car. They're not terribly spendy and they work very well. Alternativelyu, you can use two LARGE adjustable (crescent) wrenches.
The two tranny wires are for the backup lights. The speedo sensor is attached to the passenger side of the tranny somehwat near the CV joint.
The pelican article is accurate in terms of how high the car needs to be raised. I believe the torsion bar tube covers need to be about 22 or 24 inches off the ground. It's pretty high. My fog lights nearly touch the floor.
Mocha 1978 911SC. "Coco"
Old 05-29-2002, 07:54 AM
Friend of Warren
The balance point is just about where Super has it. You need to have the rear end of your car about 34" off the ground for clearance if you leave everything on the engine. That is measuring from where the bottom of the rear bumper would be if you still had it on the car.
Kurt V
Old 05-29-2002, 09:37 AM
lendaddy's Avatar
34" holy bejesus! What do you guys do for jackstands, 55 gallon drums? Oh well this is gonna be interesting!
Old 05-29-2002, 09:39 AM
Senior Member
Superman's Avatar
With your rear bumper removed, you will not need to get it quite this high. the furniture dolly idea is a very good one. I have one. Last I saw (a week ago) the dolly was on sale at Harbor Freight Tools for about $15. They also have some tall 6-ton jackstands that are handy. Once the engine is on the furniture dolly, you can use a jackpad in the jack slots to raise the car higher, one side at a time.
Old 05-29-2002, 09:43 AM
Friend of Warren
I went to Sears and got the heavy duty jackstands with a 22" lift. With those under the torsion bar covers it got the rear end up to around the 34". Remember that dolly is going to take up about 3-4" of space.
Kurt V
Old 05-29-2002, 09:49 AM
dtw dtw is offline
GAFB
My CV bolt cheater:
-spew some carb cleaner to clean out fastener heads
-tap drive in with a hammer to make sure you're fully engaged
-attach u-joint breaker bar and extension of choice
-preload breaker bar with your hand, then give the end of the bar a few smart blows with a hammer. Should pop the bolts loose no problem. I did my '72 POS and my '70 parts car this way- saved big headaches. It sucks when you think the car's going to roll off on you from wrenching so hard!!
Several BMWs
Old 05-29-2002, 09:50 AM
TurboRuf's Avatar
lendaddy,
Wait! What happened? Why are you dropping your motor?
Maybe I missed a recent post.
lendaddy's Avatar
My throwout bearing gave up the ghost. And the pisser is that at the time it had never run better. Such is life huh.
Old 05-29-2002, 10:02 AM
TurboRuf's Avatar
Ouch, sorry to hear that. I call my car "The Never Ending Project", welcome to the club.
But when she runs... it's all worth it.
Old 05-29-2002, 10:50 AM
Senior Member
john_colasante's Avatar
Please be sure to repost that feeling after you strip out a transmission mount or drop the engine off the jack or forget to install the starter ring gear after the drivetrain is all in.
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 05-29-2002, 11:01 AM
Registered Loser
Is it possible or advisable to use an air wrench on the CV bolts?
Owner of a wrecked 944
Old 05-31-2002, 06:53 AM
I wouldn't do that - that seems to be asking for trouble. I'd just clean them out as best as possible, get the tool seated as best as possible, and get a lot of leverage on it.
I have all the air tools, but to be honest, rarely use them. I've seen them cause a lot more harm than good - not really a big fan.
Old 05-31-2002, 07:07 AM
