white rabbit
Send a message via Yahoo to Don LaVance
Aluminum wheel lugs????
I recently purchased a 1988 911 Carrera and found that it has aluminum lug nuts not steel. This is new to me. Should I keep the aluminum ones or switch over to steel ones.
Car will have to endure agressive use.
If I keep the aluminum nuts what torque should I use .
If the steel ones are obtained same question.
Thanks again for all the assistance.
Don
Old 08-27-2012, 08:14 PM
m110's Avatar
Correct Lug Nut Torque
96 ft-pds
130 NM
other fun reading, this has been discussed many a time (whether or not to lubricate the studs):
http://jenniskens.livedsl.nl/Technical/Tips/7/MyTip792.htm
1988 Carrera Coupe
Old 08-27-2012, 08:19 PM
scotricker's Avatar
The lug nuts are indeed very light weight alloy. Standard equipment with the Fuchs wheels. Don't panic! 94lbs, with a torque wrench will be fine.
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 08-27-2012, 08:23 PM
Max Sluiter
Flieger's Avatar
Alu nuts are standard. Use anti-seize for a better torque-tension correlation. Porsche spec'd the torque for threads with Optimoly paste so that is what you use. If you don't, then there will be less tension in the joint than there should be. It will also help extend the life of the nuts, as the aluminum wears out.
Apply lube to the threads and the ball area that the nut seats to the wheel with.
Old 08-27-2012, 08:28 PM
Formerly known as Syzygy
Canada Kev's Avatar
Nothing wrong with aluminum nuts. If doing much track driving, you might want nuts with which you can see thread engagement. You can get nuts with the ends machined off in either aluminum or steel.
+1 for lubing the studs.
Kevin
Old 08-27-2012, 08:29 PM
Max Sluiter
Flieger's Avatar
Some race sanctioning bodies require open-ended steel nuts.
Old 08-27-2012, 08:30 PM
Mitch Leland's Avatar
The center cover plates on my BBS wheels were not seating all the way down because of the Aluminum nuts. I considered turning them down, but ended up for safety reasons buying steel nuts. Pelican Parts has them for $2.00 a piece. My local auto parts house wanted $4.00 plus each.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 08-27-2012, 09:36 PM
