Banned
1985 Carrera factory alignment specifications.
After doing an extended search, I found out a LOT about aligning these cars. Wow. If I ever do any HPDE, I know EXACTLY where to go to get ideas.
What I didn't find were the straight specs from the factory. Now maybe they are in Bentley, and I just haven't found them, but if they are hiding there, maybe a not-so-subtle hint about where in Bentley they might be found??? We don't have a shop around here that can corner balance and align - only a regular alignment shop. I have turbo tie rods waiting to install, but first I need to know what the specs are, AND if the local shop can even do the align job. This car is stock and just a street car, with some small amount of spirited driving thrown in. The tires will be Kumho Ecsta ASX no-season tires, and I'm looking to get some reasonable life out of them. No DE are planned at this time. Maybe someday, but that's a new conversation. For that kind of car, what do you think my specs should be? And why? (I'm still learning here, so any information I get is great.) |
Northern Motorhead
Eric,
A good street setup would be -1.0 front and -1.5 rear negative camber or even better -1.5 and -2.0 if you can achieve it, along with max front castor which will vary between 5.7 and 6.0 depending on your car and 1/16 toe in at all four corners. Of course,should you decide to go play DE with your car eventually you will need more aggressive camber all around and maybe 0.0 or 1/32 toe out in front. Any decent shop should be able to get those numbers for you ! Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Banned
Flat Six
Eric: The 5.7-6.0 degrees caster that Phil mentions is really the max you'll get on a stock Carrera when strut mounts are pushed all the way aft.
Max caster (all other things being equal) will improve straight-line tracking at speed. Per your initial question, factory (per Bentley p. 440-7) alignment specs are: ![]() Good luck Dale
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Banned
