Setting the dwell, distributor points
Setting the dwell, distributor points. I'm using a dwell-timing-tach "multi" meter.
1. How to connect the dwell meter: The green cable from the meter to point cable and connect the plus and ground? 2. How to measure? Having the distributor cap and rotor removed and using the start motor having someone sitting inside the car, or having the distributor cap and rotor in place and idle the engine (900 rpm)? Thankful for help. |
then check w/ the engine idling, read the meters instructions for connection, on mine there was just a ground and the connection to the black/purple wire you want the gap on the high side which is dwell on the low side(spec is 38°+/-3) if it's out of spec stop the engine and re-gap manually, wide gap=low dwell and vice versa |
Thanks a lot, my gap was very low, dwell about 55 deg. After adjusting, now about 35 deg. according to my dwell meter.
| All times are GMT -8. The time now is 01:46 PM. |
