flash951's Avatar
Setting the dwell, distributor points
Setting the dwell, distributor points. I'm using a dwell-timing-tach "multi" meter.
1. How to connect the dwell meter: The green cable from the meter to point cable and connect the plus and ground?
2. How to measure? Having the distributor cap and rotor removed and using the start motor having someone sitting inside the car, or having the distributor cap and rotor in place and idle the engine (900 rpm)?
Thankful for help.
Remi Jakobsen
911T DP targa -71 (2.7L)
Phone: +47 92844671 (Norway)
Old 08-29-2012, 01:07 PM
Bill Verburg's Avatar
Thankful for help.
first set the gap w/ feeler gauges, spec is 0.3mm+.5(0.012") for Bosch distributors
then check w/ the engine idling, read the meters instructions for connection, on mine there was just a ground and the connection to the black/purple wire
you want the gap on the high side which is dwell on the low side(spec is 38°+/-3)
if it's out of spec stop the engine and re-gap manually, wide gap=low dwell and vice versa
Bill Verburg
Old 08-29-2012, 02:40 PM
flash951's Avatar
Thanks a lot, my gap was very low, dwell about 55 deg. After adjusting, now about 35 deg. according to my dwell meter.
Remi Jakobsen
Old 08-31-2012, 02:53 PM
LakeCleElum's Avatar
Thankful for help.
Since engine won't run with cap and rotor off, you have to adjust with engine off, recheck and adjust again if necessary...Sounds like you have it now....G'luck..
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 08-31-2012, 04:33 PM
