Suddenly tight steering
Driving last night steering got very tight, lots of effort to turn wheel.
Plan to check it out tomorrow, any guesses as the most likely cause?
Glen 78SC(D) EFI Targa |
Fleabit peanut monkey
1981 911SC Targa |
The first and easiest thing to check is tire pressure.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Check the u-joints in the steering column in the trunk, they can suddenly bind up as well.
Joe D L.I. NY 82 911 SC 3.0 Swartzmetalic |
Max Sluiter
There is also a needle bearing inside a rubber coupling apparently.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Pin for the steering lock can also bind on the column and cause stiff steering. But that'd probably be immediately obvious as you went to drive away (was to me).
'77 S with '78 930 power and a few other things. |
