Oil Sump plate w/o drain Plug. Why?
Just made a huge mess in my garage trying to remove the sump plate. No drain plug, so it was full of oil, and I didn't get it off very quickly.
Is there a safety reason not to have the plug on an SC race car? If not I'm in search of the tpe I'm used to.
Mark H Class Race Car Project Old flames: 1999 C2 Race Car #78; 1983 SC Race Car; #78; 1990 C2; 1978 SC Race Car #78; 1988 Carrera; 1977 911S |
I have no idea why...bean counters? But somewhere along the line Porsche decided to eliminate the drain plug from the sump plate. You might search the aftermarket (billet carved) or the wrecked-em yards for an older plate that has the drain plug.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Starting in late 83SC's and all Carrera's Porsche put the drain plug in the block. These cars have a sump plate without a drain plug. So when you order a sump plate and don't specify the one with the drain plug, you get the one without it. Since all of the stamped steel sump plates are prone to warping, they are often replaced.
The PO probably ordered the sump plate, got the one without the drain plug and just went ahead and installed it.
1973 911T Sepia Brown MFI 1986 Carrera Meteor Gray Metallic |
yeh - search here -- somebody is making a cast Al version that looks good - not too blingy. Until then, don't forget the drain pan.
Wait until you find out about the bean counting done on the CV joints.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
The cast aluminum ones are great, but they involve the added effort replacing the stock studs because the aluminum plates are thicker.
Check out Mainely Custom for the billet plates.
http://www.mainelycustombydesign.com/engine_components.html
Steve B. 1971 T 2.2 w/Zeniths Gruppe B member 171 Mid 9 Web Site Guy |
I got the plate with the oil drain plug from Mainely Custom.......it's a quality part and they are great to deal with.
Oh yea, make sure which plate you need, either the "regular sump plate" or the "turbo sump plate". I made that mistake. Sean |
Correct me if I am wrong, but if you have an updated oil pump (Carrera pump) you cannot use the old style sump plate because of clearance issues with the drain plug.
Rich
1976 911/S/SC/BASTARD Mid9 Member #12 |
The purpose for the rounded-bottom sump plate without a drain plug was as Rich noted ... to allow use of the Carrera oil pump with fixed, rounded intake screen to be used in older cases that required a steel sump plate.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
cycling has-been
73 911T MFI, 76 912E, 77 Turbo Carrera |
The no drain plug was from a German regulation to stop people from doing their own oil changes and then dumping the oil. Forced them to go to the dealer where they would suck the oil out with a pump and dispose of it properly. Can't remember where I read this but it could just be a Porsche urban legend.
Robert Currently Porsche less (but the wife has 2) |
I'm still a newbie........I had no idea I had a turbo sump pump. I ordered the wrong one the first time and had the problem with the rounded screen.
That's when the people at Mainely explained the difference and sent me the correct one. Changing the oil is a breeze now.
Sean M '77 911S Targa Ice Green |
I just finished modding my sump plate due to the fact that i could not get the newer style plate to work with my sump screen due to clearance issues so I mig welded a 3/4 " nut to the bottom and added a crush washer then cut it to make sure it was not going to interfere with anything. here are some pics.
78 911 SC "Scratchy" 2004 Mini Cooper S "Pele" (gone but not forgotten) 1979 classic mini clubman-"Coolio" Last edited by Norm Faustino; 06-29-2006 at 09:27 AM.. |
Still picking up kitty litter today, there was alot of oil!
The screen was smooth, without an indentation for the plug that I vaugely remember from my other car. So maybe I have a carrera pump. I had a bottom end done in 04 after a piston disinegrated, so I need to check with my wrench to see what he put in. I'll check out the Mainley item, as I don't need to learn my welding skills on a sump plate. Thanks for the insight!
Summary:
1. Mod your own sump plate 2. Buy the other kind 3. buy a new Al billet one 4. buy a new Al cast one - discussed on a recent thread - Note the reports that not all solutions will work on all cars.
I just received the billet one with the plug from Mainely Custom. It's a beautiful piece, complete with gaskets, nuts and studs. I thought the new studs were an extra bonus— didn't realize they were required because of the thickness. DOH! Oh well, 6 of the old studs came out when I was removing the cover anyway.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
911SC Oil Sump Plate Gasket
Hi,
I just bought the Mainly Custom oil sump plate to replace my original pressed steel unit. The Mainly kit came with two (thin) gaskets; do you use both or just one (and have a spare)? They are not very thick, and I have a spare OEM from Porsche which is substantially thicker. Does it need any gasket sealant as well, or do they go on dry? |
Iirc, I just used one gasket and no sealant.
Senior Advisor
you know this thread is 6 years old, right
08 Cayenne Turbo |
Tom
68 Beetle 68 to 72 sold 72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army 67 VW split window 74 to 76 sold 81 VW caddy 81 to present |
