Banned
1973 911E ride height question
I am plan to build a 1973 RSR, I put 1987 930 front steering system(included suspension and brake system), but my ride height seem a little bit higher, the front torsion bar adjust screw is in very low position, is that correct?
Need you guys help!
Many thanks
Old 08-31-2012, 10:01 AM
Max Sluiter
Flieger's Avatar
You need to undo (counterclockwise, loosen) the screw. If you cannot because it hits something then the front end needs to come apart partially so that you can re-index the adjusters on the torsion bar splines. Make sure to move both adjuster screws the same number of turns.
Old 08-31-2012, 06:57 PM
