Compression test
I currently have my engine out and sat on a trolley on the floor. I was wondering if it's viable to do a compression test now with the engine sat on the trolley? I was thinking of pulling all the plugs so compression and movement is minimal and then applying 12 volts directly to the starter.
Anyone think this is a bad idea? |
Not without oil circulation.
You can do a leakdown test with it out.
So 5 turns per cylinder under the power of the battery is too risky without oil?
| All times are GMT -8. The time now is 06:05 AM. |
