Compression test
I currently have my engine out and sat on a trolley on the floor. I was wondering if it's viable to do a compression test now with the engine sat on the trolley? I was thinking of pulling all the plugs so compression and movement is minimal and then applying 12 volts directly to the starter.
Anyone think this is a bad idea?
71 Bahia Red 2.2E (sold) 72 Silver 2.4 T (stock except for a 2.8 big bore kit) 69 Chartreuse 2.0E |
Not without oil circulation.
Ed 1973.5 T |
Platinum Member
You can do a leakdown test with it out.
So 5 turns per cylinder under the power of the battery is too risky without oil?
