Senior Member
Post how does a 3.0 piston weigh
what is the weight range of 78 911sc 3.0 Mahle piston?
[This message has been edited by osidak (edited 08-10-2001).]
Old 08-10-2001, 03:50 PM
Bill Verburg's Avatar
Post
Spec book only says max difference in a set is 6 g.
Bill Verburg
My Home Page My Pelican Gallery page My Porsche Owners Gallery Page
Old 08-10-2001, 03:59 PM
Early_S_Man's Avatar
Post
osidak,
Since you don't really know the year of your replacement piston ... it might weigh anything between 636 g and 676 g.
Do you know the weight class markings ( --, -, +, ++} on all six of your 'good' pistons?
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
[This message has been edited by Early_S_Man (edited 08-10-2001).]
Old 08-10-2001, 04:20 PM
Bill Douglas's Avatar
Post
Osidak, I would take your cracked piston and the new one to a machine shop and get them to compare the weights. Warren is it ok for Osidak to file metal from the moulded inside of the piston to get the weights within a gram of eachother ?
Old 08-10-2001, 04:34 PM
Senior Member
Leland Pate's Avatar
Post
When I had my pistons balanced, I was really suprised at how much material the machinist had to remove from the undersides. On the mahles, under the wrist pin on the square side is where he removed quite a bit of material.
On a couple he said he almost had to lightly shave the thick part of the dome (under side) to get them all within a gram of each other.
He took the lightest piston, pin, circlip combo and used it for the average weight.
JDUB has them now...maybe he can post pics!
Old 08-10-2001, 04:41 PM
