The Bavarian
Shall I replace the sway bar bushings? ('80 SC)
Hi,
I'm wondering if I should replace the sway bar bushings front and rear of my '80 SC. Overall, they do not look brittle or cracked but solid. However, due to the overall condition of the car I suspect they have not been replaced before.
The LH end link of the rear sway bar has been hit from below and definitely needs replacing.
The picture below is from the LH sway bar bushing (RH loose the same). I'm wondering if this is really the correct bushing since it a) doesn't enclose the bar completely but shows a significant gap and b) looks quite loosee. Is this how they are supposed to be?
On the front sway bar, the bushings look snug and solid.
Should I replace all bushings anyway while I'm at it?
Thanks, Manfred
Old 09-03-2012, 06:19 PM
Recreational Mechanic
Nickshu's Avatar
That's what mine look like...30+ years old like yours. I have replaced most of my suspension bushings with poly-graphite, but never got around to the sway bar bushings. Honestly I don't think that replacing them will result in any performance gain, they are not knocking and the bar is still held tight in place. I plan to replace them the next time I have a reason to do any suspension work, but not planning a special project to replace them.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 09-03-2012, 08:48 PM
Rubber bushings........
Mannfred,
Those rubber bushings are ill-fitted. Either they have shrunk or the wrong size. The sway bar bushings should be snug but not too tight and have minimal gap when installed. They age and get hard over the years. Replace them as needed.
Tony
Old 09-03-2012, 08:55 PM
