Senior Member
For those that don't remember, while putting my engine back together I dropped a piston and cracked the skirt. I ordered a replacement from EBS. I just got it in today and and cleaned it up here is what I found
**What I have currently 78 911sc Euro 3.0 **On the cylinder (Mahle) I have the following stamped 1 and a 5 in a triangle **The cracked piston is a Mahle On the underside it has the following markings Mahle 37 28/8 C011 93L7++ On the top of the piston it has The Number 1 stamped and the Letter E **The replacement piston is also a Mahle On the underside it has the following markings Mahle 36 40/7 C021 93L7+ On the top of the piston it has The Number 0 stamped and the Letter E The Question is are these two pistons interchangeable? Or do I need to call EBS and have them exchange it? Osidak 78 911sc [This message has been edited by osidak (edited 08-09-2001).] |
the piston stamped 1 is up to 100th of a mm. larger across the skirt than the 0 piston. not a big deal. compare the weights and the skirt measurements and if it's basically the same, use it.
[This message has been edited by john walker's workshop (edited 08-09-2001).] |
Senior Member
John
Thanks for the quick response What is the max allowable difference in size and weight I put the replacement piston into the cylinder with out rings and it had some play. Is that ok? How do you suggest I way them? Osidak |
Senior Member
bump
weigh it on a scale of course. maybe your local auto machine shop has one. 7g is max., right on is better. 1/100 of a mm is nothing, basically. they all need some skirt clearance. compare with a micrometer. this is why it's hard to do these jobs at home. no tools.
Tools are good.
When combined with "touch", they become useful. I have no idea what brought this on.... JPIII |
