Roland? Do the really early (2.0) connectors give a different resistance reading than later, but pre '74 connectors?
Just a followup to what I said above about the availability of Bremi resistor ends - my BMW mechanic has them - NZ$9.50 (less than US$5 each).
Anyone who works on '02s should have them if anyone wants to try.
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
Senior Member
Hello
The early straight connectors have the same resistance but they wheren´t tough enough to withstand the high Voltage for a long time. Porsche also had spark plug fouling problems with the early S engines so you had plugs for cruising and plugs for driving. In 69 the first Bosch silver electrodes came with the 2,2 S and where also used on the 2,0 S. Grüsse |
