donnmaddy
Can any one tell me if the cover plate on the front of a G50 transmission be removed with the engine and transmission installed or do they have to be removed. I have a metallic looking transmission fluid dripping from around one of the lower nuts on the transmission. BTW I replaced transmission fluid not too long ago and it looked clean so I checked inside of transmission and still looks clean.
More info needed. Which model G-50? Which cover plate? A photo would help.
donnmaddy
Did you install a new crush washer on the fill port when the fluid was changed?
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
Could that just be anti-seize compound. If there was alot put on it would run some after it got hot.
I have seen someone put anti-seize compound around the bell housing to engine surfaces with dripping that looks alot like that.
Valkyrie Last edited by Two Rivers; 09-02-2012 at 03:16 PM.. |
donnmaddy
I checked to see if oil was coming from fill port and it is not. I have checked all around this nut and that is where is seems to be coming from. It does look like it could be anti-seize but I have not used any on the front of transmission nor have I seen any in that area before. At one time there was a large puddle of transmission fluid under the car but only one time and only a drop here and there before the puddle and it was clean fluid.
Is it coming from the overflow tube and dripping down from there? Might have just been a slight overfill at last fluid change.
donnmaddy
Deadeye Could you tell me where to look for the overflow tube?
Schleprock
There's no overflow tube. It's a hex fitting (like a tall hex nut) that sits on top of the transmission (along the "spine" or centerline of the trans. It has holes in the hex that are a vent path into the transmission case. The hex fitting is hollowed out to allow the gear oil to puke out when it heats up, should there be too much fluid in it.
Kevin L '86 Carrera "Larry" |
donnmaddy
Thanks Kevin that must explain why I got the one and only puddle of trans. oil on garage floor. I would like to thank all of you for your help. Don
Thanks Keven that must be why I had one and only one puddle of transmission fluid on garage floor. I had looked for a overflow tube but could not find one. I would like to thank every one for there help. Don |
