Heating System full OFF (3.2 Row 85 with Clima), but driver COLD passegger HOT?
hi i have 3.2 Row 85 cabrio whit OEM clima, whit heater full off the left part(passeger) is HOT! (interior whit control 3 speed...i suppose NO autoheater...mmm the difference?)
thanks!
danilo
italy
---the difference between insanity and genius is success--
Old 09-04-2012, 06:58 AM
Dublinoh's Avatar
There are separate heat box valves for each side...sounds like one side is stuck directing heat to the cabin...these get rusty and stick easily. The boxes are located forward of the heat exchangers under the car...may respond to a little oil and some manipulation by hand while an assistant moves the lever in the car. You can also check for the correct movement of the cable.
Old 09-04-2012, 07:24 AM
Check the heater air valve under the car on the right hand side. It is probably stuck in one position from rust.
hi and thanks, no the heat box valves work perfectly same cables (((
(i have "rebuilt" the silent block front and rear, the shock abdsorber ect ect less than a month ago)
- the whole right side begins to heat up and blows hot air after 10/20 km from the start and seems to do more now that gets cold (now 10C°/50F...10 days ago 41C°/106F...north italy...not south italy))
Old 09-04-2012, 07:38 AM
Do you have heater levers in the front of the box with the fan control? One or two levers?
JR
Old 09-04-2012, 07:58 AM
on the dashboard i have ONE level for the fan (84/86 i suppose) this fan run perfectly
mmm...if possible on the box valves...is not perfectly open/closed? or failed internally...
Old 09-04-2012, 08:14 AM
I was talking about a lever on the floor, by the handbrake.
JR
Old 09-04-2012, 08:32 AM
all right!
thanks JR and Others
Old 09-04-2012, 08:46 AM
