Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Mistery filter in fuel tank ??
On my CIS car, the discharge plug underneath the fuel tank comes with a cilindrical mesh filter.
However, both the supply and return lines don't seem to go through the filter, so what's it there for ?
Old 06-11-2013, 07:03 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Protect the pump from crud in the tank
Old 06-11-2013, 07:08 AM
Banned
Yes, I assumed that. But the filter seems to be unconnected to the in / out fittings.
Old 06-11-2013, 07:11 AM
db_cooper's Avatar
It seals at the top edge against the tank internally at the swirl pot cavity..the bottom speaks for itself.
You are doing the right thing replacing the in-tank filter. How bad was it?
Old 06-11-2013, 07:42 AM
Banned
Actually, I'm not replacing it. It was just cleaned along with the tank.
But the tank was really bad, there was lots of a kind of coarse dust.
Old 06-11-2013, 07:45 AM
db_cooper's Avatar
Only about $45 from our host..get the "O" ring too.
This is a picture of the swirl pot..you can see where the filter seals at the upper side against the pot..and the fuel is drawn up below
Old 06-11-2013, 07:53 AM
Banned
Now it's clearer !
My big problem was not in the supply line but rather in the return line. It was getting clogged and causing stuttering around 2K rpm.
Took me 3 years to get to this. Guess I'm a slow learner...
Old 06-11-2013, 08:00 AM
porwolf's Avatar
Originally Posted by prebordao View Post
Now it's clearer !
I also found the return line input barb to the tank plugged up with old gasoline crud after car was sitting for 16 years in the garage. After prodding, probing, and thorough cleaning that barb to the tank, so that compressed air flowed freely into the tank, the car ran fine and has been for 2 years now with no problems.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 06-11-2013, 09:35 AM
