Update on Hot Start Problem
Ok, here is some data I gathered last night.
Voltage (ignition switch "off")
1. Voltage b/w battery terminals: 12.57
2. Voltage b/w input from battery on solenoid and ground strap (GS): 12.57
3. Voltage b/w input from battery on sol. and yellow signal wire on solenoid (wire from ignition switch): 12.57
4. Voltage b/w input from battery on sol. and "pigtail" (braided copper wire extending from body of starter motor to solenoid): 12.57
5. Voltage b/w yellow signal wire and GS: 0.0
6. Voltage b/w "pigtail" and GS: 0.0
7. Voltage b/w yellow signal wire and "pigtail": 0.0
Voltage (ignition switch "on", by the way, thanks to whomever suggest the vice grips on the key with string to activate the switch!) First voltage is before I trigger the key, the voltage afterward follows the arrow.
1. Voltage b/w battery terminals: 12.57 --> 12.19 (dropped substantially, I know)
2. Voltage b/w input from battery on solenoid and ground strap (GS): 12.57-->12.19
3. Voltage b/w input from battery on sol. and yellow signal wire on solenoid (wire from ignition switch): 12.57-->2.05
4. Voltage b/w input from battery on sol. and "pigtail" (braided copper wire extending from body of starter motor to solenoid): 12.19-->11.62
5. Voltage b/w yellow signal wire and GS: 0.0-->10.16
6. Voltage b/w "pigtail" and GS: 0.0-->0.484
7. Voltage b/w yellow signal wire and "pigtail": 0.0-->9.8
Let me see if I can make that easier to read:
Before (off) After (on)
1. 12.57 12.57-->12.19
2. 12.57 12.57-->12.19
3. 12.57 12.57--> 2.05
4. 12.57 12.57--> 11.62
5. 0.0 0.0--> 10.16
6. 0.0 0.0--> 0.484
7. 0.0 0.0--> 9.8
Additional information:
When I turned the ingition key, I heard the solenoid click and when I would relax the key, I could hear the solenoid release.
Ran out of time beyond this, so the only thing I have determined from this is that it is most likely not the ignition switch (pulled the connector behind the dash and it looks fine (nice and clean).
I will compare these values to a Tech Article I saw based on some hot start issues.
Any thoughts from those steeped in starting system knowledge?
Old 06-04-2002, 04:49 AM
