Recreational Mechanic
Nickshu's Avatar
Are Sway Away (adjustable) rear spring plates required for corner balance?
I'm messing with the ride height on my 911. I previously have had it lowered to below euro specs using the stock spring plates and Neatrix bushings, but would like to raise it to actual euro specs...then later do corner balance/alignment along with new tires and new rear shocks.
I have a set of Weltmeister sway away swing plates in a box in the basement, I bought them *literally* 10 years ago and never got around to installing.
Do I have install these adjustable spring plates installed in order to have the car corner balanced? Or can it be done with the stock rear plates?
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 09-06-2012, 05:55 PM
HarryD's Avatar
The adjustable plates make it easier but not required.
My car has had it done with the stock (non-adjustable) plates.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-06-2012, 05:56 PM
Max Sluiter
Flieger's Avatar
You can do it with non-adjustable plates but it is harder. I would just stick with the factory style adjustable spring plates that you should already have.
Old 09-06-2012, 07:50 PM
