993 no spark from coil
been lurking on this site a while but now have a serious need. recently installed a 1995 3.6 non-variocam engine in my 1981 SC track car. used the Patrick fly wheel but not their entire kit. engine runs well but does not get spark from the right side (as you look at the engine) coil pack. got good power to both top-side terminals but nothing coming out the coil wire going into the distributor. installed brand new coil backs and same problem. am completely stumped. any help is appreciated
thank you ![]() |
Grand Am/IMSA Data Guy
Interesting problem. Have you tried swapping the coil wires (black and green I think) from one coil to the other? I'd swap the exciter connectors (maybe 993 only used one, can't remember) as well to see if the problem is in the wiring,
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
thanks for the input. will try swapping wires this weekend. does anyone know which pins on the DME to look at for this coil?
thanks |
