Chain fence eating turbo
X-post: G50/01 1st gear launching longevity with boost
First off, I know these are not drag cars, so spare the words of wisdom please.
![]() I am going to be hooking up launch control in my turbocharged Carrera 3.4 that has MegaSquirt. This should allow me to mash the throttle to the floor with the clutch in and bring up the boost to whatever amount I set it to by timing retard, RPM, etc. Was thinking about 4-5k RPM and hopefully seeing around 5 PSI or so before releasing clutch. Question is, will the G50/01 withstand this much power off the line in first? I have the Kennedy Stg II PP and kevlar disk. Clutch is up to par. Is the diff cover a weak point? I know the cover is very light and feels like it can't take much torque but wasn't sure.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Guess I'll be the guinea pig.....
gearhead
Nah. You aren't a guinea pig...
The Wheelies are back
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
LOL. I seem to remember Juan posting years ago that the axles were the weak link, but that he preferred to regarded them as a "fuse" and just replace them, rather than the entire tranny...
'77 S with '78 930 power and a few other things. |
Could you explain how launch control works for these cars?
63 356 So Called Outlaw 76 930 |
4.5K RPM Question is, will the G50/01 withstand this much power off the line in first? Yes, Axle's won't either the inner hub our outter hub or both you can skip to the 1.25 mark Sunday Fun - YouTube I have the Kennedy Stg II PP and kevlar disk. Clutch is up to par. Not for long if you plan to do this often Is the diff cover a weak point? Yes a Billet side cover is a must
10.76@139-1/4 mile 0-1 mile 193MPH I Love to Shine Cars
Severely retarded timing with random cylinder spark removed. Hold pedal to the floor and the motor is in an artificial load.
I've done some high-RPM launches in 2nd and the disk looked really nice afterwards when I tore it down. Seemed to have no material removed and a nice yellow color - no blackening or glazing over. I thought that was the claim to fame for kevlar disks.....
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel Last edited by Tippy; 09-10-2012 at 07:52 PM.. |
gearhead
The thing about 1st gear is that with any sort of significant power, you'll have more power than traction because 1st is such a short ratio. It's hard to break the gear if you're spinning the wheels all the way until you make the shift to 2nd.
Thanks Matt, that seems to be the concensus from the 930 board too.
