pjv911's Avatar
Send a message via AIM to pjv911
What is the ideal max advance timing....
I would like an experienced opinion on where I should set my total advance timing at on a 2.7 cis motor that runs on 93 octane . Im seeking maximum power while staying a few degrees short of detenation . Please no guessing I can do that myself. Im afraid I wont hear detonation over the fan and exhaust so I dont want to take any chances.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 06-04-2002, 07:49 PM
Early_S_Man's Avatar
Porsche Crest
38° BTDC, per the '74 spec book ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-04-2002, 09:09 PM
Let me add:
The 38º rule probably applies, but it may not be the optimum. I don't know the particulars of your engine, but variations in compression ratio, fuel octane, altitude, piston dome shape, combustion chamber shape, carbon buildup, inlet air temperature, etc. could change this maximum figure. The best way to maximize the advance is to put it on a chassis dynomometer and check for the max. power at various rpm's under load while somehow monitoring threshold detonation. After testing through the rpm range, you can plot a custom distributor advance curve that stays safely below the detonation threshold. As you might imagine, this will take time (& money).
Sherwood Lee
http://members.rennlist.org/911pcars
Old 06-04-2002, 11:43 PM
