Stock front sway bar removal?
I haven't worked with a stock front sway bar before so I want to make sure I'm on the right track. This is a '69 912 which I'm sure has been untouched for quite some time.
Should I be able to slide the bracket/cover over the rubber bushing and over the end of the bar? I trimmed off the rubber a bit but to see if I could get it started, but it's not budging (yet). I just wanted to be sure there isn't an easier way. Thanks for the help. Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
