I know I have S brakes on the front of my 1973 911e.
What were the options for the rears? I have an alloy and one steel??? The difference is due to having to replace the caliper prior to really knowing about the car. Now I am looking to replace the steel rear caliper with an alloy, but can not find an "s" rear?
Jon '73 911e (ROW 3.0) www.jonswanson.home.comcast.net |
Jon,
There are no alloy calipers for the rear! All '69 thru '89 911's use the Ate 'M' caliper. Are you sure the 'alloy' one is not just a new replacement that has bright, shiny cadmium plating?
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
The one I replaced it was an "M" it is now rust colored.
The other has the same finish as my front "S" calipers.
Jon,
Does a magnet stick to it? Can you post a pic? Same 'Finish' is pretty hard to comprehend ... as no other caliper on the planet looks like an 'S' Ate caliper ... not even close! A painted 'M' caliper that matched the 'S' caliper shade from the factory still wouldn't look the same to me, but others might disagree!
There is no way an S or A caliper which have 3.5" OC ears will bolt on to a rear M mount with 3" OC mounts. The magnet test will differentiate an aluminum S from an iron A or M.
