Josh
rubber door stop and sticker question
Two quick questions:
How are these rubber pieces at the top of the door frame attached/how do I remove them?
I found an old post about these stickers but I thought I would check again. Anyone making reproductions of these door VIN stickers?
Old 08-31-2012, 09:10 AM
Classic's Avatar
I don't know about the sticker, but the frame stop is held in with two small screws, or at least should be.
Don't lose them as they are NLA
Classic 1969 911T
Old 08-31-2012, 02:58 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Door Sticker.
You don't want to remove that either.
Not legal to reproduce.
Verrrrrrry expensive to replace from the Porsche folks.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-31-2012, 03:10 PM
Josh
They must be tiny. I'll take a closer look. Thanks!
Old 08-31-2012, 03:11 PM
Josh
Targa - do you know what the replacement process is? Is it through Porsche?
Old 08-31-2012, 03:13 PM
Weekend Mechanic
vulcan300's Avatar
I looked into replacing the stickers on-line and found that as long as you have a high-res picture of the original there are companies that can and will reproduce it. If you don't have a high-res image of the original you may be out of luck. If you find out more about getting one from Porsche I'd love to hear about it.
J
86 911 Carrera Targa
Old 08-31-2012, 03:32 PM
Josh
I'll look into it. 90% of my car is bare metal, I don't think I can live with leaving a small square of paint in the door frame.
Old 08-31-2012, 04:51 PM
Sticker Replacement
Yes, throught the dealer, and it is quite a process.
Having the original will help.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 08-31-2012, 05:45 PM
I took the likely original window channel out of my '66 window frames and don't recall seeing the rubber pieces. It appears from the diagram and picture that they fit in the top channel, correct? How many and what is their purpose? I will be assembling my frames soon.
Old 09-01-2012, 01:25 PM
E Sully's Avatar
PM Sent
Ed
1973.5 T
Old 09-01-2012, 01:43 PM
E, if you sent the PM to me I didn't receive it. Send direct to jimchambers41@hotmail.com
Old 09-07-2012, 03:57 PM
Josh
Jim - the PM was to me about a sticker source, that so far, looks like it is going to work out. I'll post some follow-up when I know more.
My car is a 75 and the black pieces are on the top of the door frame. I don't know about earlier cars. I think their purpose is to keep the top of the door from banging against the car body.
Old 09-08-2012, 05:17 AM
Burnin' Rubber
Koizumi's Avatar
I'm curious about the sticker source. I need a respray done but I don't want to cover my original intact sticker.
Old 09-11-2012, 09:30 PM
dshepp806's Avatar
What do painters typically do with any/all stickers on a repaint?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-12-2012, 04:02 AM
There's a guy on the 911S Registry that is reproducing them. I haven't bought one, but they seem to be pretty good replicas.
vin safety sticker for sale.. finally
Old 09-12-2012, 08:07 AM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest
Doyle
Carefully remove them and then re-apply.
Kees.
Old 09-12-2012, 09:33 AM
Kees.
Problem is these VIN stickers are designed to tear apart if you try to remove them, that is why they have the circular pattern imprinted on them. To try and prevent fraud I guess.
Old 09-12-2012, 11:19 AM
dshepp806's Avatar
Wow, bugmeat,...I never thought of that. I do know they are somewhat "punched", this would make removal a tricky process......
Mine will be in for repaint, end of year. I will definately cover off on their methodology of preservation (important to me).
I may cross post this in the autobody/paint form and see what those guys have to say.
Interesting footnote, Bugmeat.
BEST!
Doyle
Middle Georgia
Old 09-12-2012, 02:56 PM
Josh
Mine shredded when I tried to remove it with heat gun and razor blade. I ordered one from the above listed link. I'll let ya know how it looks when I get it.
Old 09-12-2012, 05:28 PM
