Noise from airbox
Hope someone can help me out. I have a 89 911 with 141K. While driving yesterday, about 2 hours into a drive, a strange noise started while accelerating through 2000-2500 RPMs. I initially thought it was the transmission or a heat shield vibrating but the transmission was shifting fine and once the engine cover was opened the noise seemed to be coming from the air-box area. The engine runs fine, no lack of power or misfiring however it may be running a bit rough at idle. The noise is hard to describe, it sounds like a vibration with a lower pitch growl to it, it is not intake noise, not a normal intake noise anyway. The noise appears around 2000-2200 rpm and seems to go away after 2500 or I cant hear it anymore due to other engine noises.
Does anyone have any idea what this may be? Loose intake manifolds? Air-box? Cylinder not firing at low RPM?
Old 09-10-2012, 06:10 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
Failed timing chain tensioner possibly? Does it sound like dragging a metal chain across a metal trash can?
Old 09-10-2012, 07:20 PM
steely's Avatar
Welcome.
Do the symptoms sound familiar to this?
87 carerra intake/throttle body noise
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 09-10-2012, 08:27 PM
It doesnt sound like dragging metal chains, It may be similiar to the noise from the other thread but my noise only comes on at 2000-2500 RPM.
Old 09-11-2012, 11:02 AM
dshepp806's Avatar
Although maybe different from yours',.....I occasionally heard a vibration-based noise,..and ultimately found it to be a loose nut on the cat converter shield......go figure?
That is, to say, be sure (first) that nothing is loose somewhere......
I hope yours is as benign as mine.
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-11-2012, 02:19 PM
It turns out that the bolts holding the airbox to the throttle body were loose and one was backed out and sitting inside the box. Tightened all of them back up and it runs fine. Thanks for the responses.
Old 09-13-2012, 11:22 AM
