When is it time to change transmission mounts
Hi guys,
I have a 71 911T that has never had it's transmission mounts changed. How do I know when to change them? They do look worn. I am confused on the parts. It says here at Pelican that I need to buy the entire Transmission bar instead of just the two transmission mount inserts that are also used for the engine mounts. Is this true for a 71? The Porsche dealer parts department told showed me a diagram and it shows just the inserts for replacement? Any suggestions.
mh
Old 09-13-2012, 09:18 AM
Weekend Mechanic
vulcan300's Avatar
I don't believe replacement inserts are available. If the 71 trans mount is similar to that in a 69 you have to weld new mounts onto the bar, or replace the entire assembly. Your best bet is to check with WEVO. They offer a service where they take your old mounting bar, cut off the old mounts, weld new ones in place, and then powdercoat the whole thing so it looks like a brand new piece. You end up with refreshed mounts using modern polymer cushions.
86 911 Carrera Targa
Old 09-13-2012, 09:50 AM
gearhead
That is correct. They are not designed to be replaced. There are a few aftermarket solutions, or you shop for a good used one.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-13-2012, 10:10 AM
Targa,
Thanks. I checked out Wevo site. Ok. The 71 Trans Mount has it's mounts welded inside the bracket. The dealer diagram is wrong, it shows inserts are available. Thanks guys
mh
Old 09-13-2012, 10:24 AM
