Juggino's Avatar
Send a message via AIM to Juggino
How to replace bulbs on the instrument cluster
I have a 1978 SC. ,I bought a new set of bulbs for my gauges and when I pulled the tach out, I notice the bulbs are in red sockets. How to take the socket off the gauge? It seems like there is a spring in there. I tried twisting, twisting while pushing, twisting while pulling the red socket to see if it will pull out but no dice. I was afraid to just pull the red socket out of the tach. Can anyone tell me how the sockets come off so I can change the bulbs?
Old 09-14-2012, 04:36 PM
Weekend Mechanic
vulcan300's Avatar
The red part is a component of the socket. If you pull it out or you will break the socket. I'll dig up the thread that explains how to replace a bulb and post it shortly.
86 911 Carrera Targa
Old 09-14-2012, 07:56 PM
Weekend Mechanic
vulcan300's Avatar
The picture in the first post shows what the bulb socket looks like when it is out of the gauge. You place a small thin bladed screw driver under the rolled edge of the metal body of the bulb holder and lever it out of the gauge. Once you've replace the bulb just push the bulb holder back into the gauge. Good luck
Old 09-14-2012, 08:00 PM
pete3799's Avatar
^ What he said.
The metal part is what you have to pry up on.
Pete
79 911SC RoW
Old 09-14-2012, 08:05 PM
Juggino's Avatar
Thanks guys, I get it now. Didn't realize the metal was part of the socket.
Old 09-14-2012, 09:14 PM
Weekend Mechanic
vulcan300's Avatar
I was in the same boat when I first tried to take the lights out. And it was a fellow Pelican that gave me the answer back in the day :-)
Old 09-14-2012, 09:23 PM
froggert's Avatar
make sure the bulb is secure in the socket before putting it back into the gauge. i just swapped mine over to led's this evening and lost one in the tach. opening the gauge to fish out the bulb is a pita.
Old 09-14-2012, 09:33 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
I hope you got the LED bulbs..
Old 09-14-2012, 09:57 PM
schumicat's Avatar
I would get the 4v bulbs. they are (naturally) twice as bright as the standard 2v ones, and increase the brightness from "really dim" to "decent." you can get them on ebay (they ship from India, which is apparently the only place they are made/sold).
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 09-15-2012, 05:42 AM
