Stackett's Avatar
964 Brake Calipers on an 80 911/Will it work?
Will a set of Front and Rear brake calipers from a 964 bolt on to an 80 911? Is there a difference in the bolt patterns and if so, how hard is it to modify?
Thanks.
Scott Tackett
_______________
1980 SC Targa (His)
1975 911S 25th Anniversary Edition (New addition to the family)
2003 VW Beetle Convertible (Hers)
(I'm not going through midlife crisis, I'm just reliving my childhood obsession!)
www.inhousenetworking.com/911/index.htm
Old 06-06-2005, 12:18 PM
Bill Verburg's Avatar
Look here and try searching. It can be done 3 ways, 2 are ok one is not. You decide which is which.
Bill Verburg
Old 06-06-2005, 12:27 PM
Stackett's Avatar
Anybody else know if they will fit?
Scott Tackett
_______________
1980 SC Targa (His)
Old 06-07-2005, 05:11 AM
911-32's Avatar
No, they will not bolt on. Yes, they can be made to fit, but not with std 1980 front discs and not without modifying/adapting all 4 calipers. This has all been covered before if you search, but that is the simple answer.
Old 06-07-2005, 05:35 AM
MBruns for President
JeremyD's Avatar
Read this first: http://home.nycap.rr.com/wmv/generalbrmd.htm
Here's everything you need to put 964 calipers on a 911
http://www.vehiclecraft.com/Brakes/VCI911_2_964.htm
More reading
http://www.rennsportsystems.com/~porsche/1-sf.html
BTW - Bill Verburg knows more about brakes than anybody. So in response to your question - it's yes, it's been done. Is it direct bolt on? No - see the links. And I recommend you read what Bill has written about brakes. It will save you mucho cost, headache, and frustration.
Old 06-07-2005, 05:38 AM
Thanks for all the help folks and the links about brakes!!...I didnt think they would fit but was not sure about the mods.
Old 09-16-2012, 10:18 AM
ivangene's Avatar
edit post after seeing this is 7 years old
Ed M
86' Coupe
Old 09-16-2012, 10:50 AM
