Platinum Member
993 gearing/5th gear-5300-MPH?
Can anyone tell me how fast(mph) 5300rpm in 5 gear would be with a stock 993 6 speed transmission?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
There were 6 different 5th gears in 94/95(the only years I have info on) all have 3.444 (9:31) final drive
the formula Bruce Anderson provides in his books is MPH = (rpm * rolling radius * .00595)/(trans ratio * Differential ratio) for a 265/40x17 Bridgestone S0-3 slr =~11.7" with a G50/21 1.027 this works out to a theoretical 133.8 mph in 5th at 6800rpm the rolling radius may also be calculated by measuring how far the car rolls for an intger # of rear wheel revolutions
Ok, I understand everything but the constant. Where does that .00595 come from?
The rpm units need to be changed to rph so a *60, the slr units need to be changed from " to mi so a /(12*5280) is required.
(2*pi*60)/(12*5280) = .005949986 ~=.0059
Platinum Member
So that puts my speed at about 112 mph (12.5" radius) I think I was going faster, based on previous speeds at this racetrack (Watkins Glen, end of back straight) and conversations with other drivers that I run with(& passed!). Can my Tachometer be off from the 3.6 conversion? Am I doing the math wrong?
5300*12.5*.00595/1.027*3.444=111.44 mph. I don't suppose tires can 'grow' that much at speed? (I need a 16" radius to be doing 140!)
I checked BA's work(not that I don't trust him) by deriving the equation and constant from first principles. The math doesn't lie. You can also check against Steve Timmons gear charts which agree with the formula.
Gear charts The tires do grow a small amount, but that won't change the result much. I don't know how to check the accuracy of the tach, I've always just sort of believed what I see in that regard. You going to the Glen for the club races? I'd love to see your car.
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 06-05-2002 at 04:50 PM.. |
Platinum Member
Haven't raced this one yet, I think I'd be trounced on in gt2 with a stock 3.6. But I will be there for 48 hours/zone1 the end of this month, and at NNJR Pocono in early July.
And I believe the charts/math. Guess I'll just have to enter the esses without the lift....
