IMS Stud snapped off while using LN Tool
I decided to do the IMS upgrade from LN engineering dual row bearing. I attempted to remove the bearing with the LN toolkit and the support stud snapped off inside the LN tool. Then I decided to use the "Easy Out" tool. After about 10 seconds of trying to get the "Easy out" tool inside the bearing, the copper wire broke off at the threaded piece. As you can see this is not going well. Should I try to call LN and get another "Easy Out" tool and take that chance or should I go ahead and buy a bearing puller?
Originally the LN tool did not budge the bearing at all and that is what caused the stud to snap. What's the chance the "Easy Out" tool or bearing puller will work? Any other way to get it out? |
Platinum Member
I'd suggest posting this in the Boxster or 996 forum.
I've done the IMS on my Boxster, I believe the procedure is very similar on a 996/911. Having said that, mine was uneventful. I strongly suggest contacting LN Engineering for advice. |
call Jake Raby
he will get you out of this
Ed M 86' Coupe |
Red Line Service
A good quality internal bearing puller, such as snap-on collet style, will do it. BUT make sure you use the LN "tube" for your base. You MUST pull against the IMS, NOT the engine case. You'd probably be better off to wait for a replacement from LN.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
