gearhead
Originally Posted by Dsdepew View Post
So, does that infer that all T's were RoW and not US bound? Thanks for the input btw.
That is correct. We did not get the T imported to the States in 1968. We didn't see it until 1969.
Furthermore, the 901/03 is the standard optional 5spd gearbox for a '68 911T. Standard spec would have been a 901/10 4spd, but if the original buyer or the dealer spec'd it with 5spd, 901/03 would have been the box put into the car.
I owned a '68 911T for about a year. Fun little cars, albeit underpowered for the weight because of the 110bhp engine.
Regards,
Matt
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-18-2012, 09:49 AM
djpateman's Avatar
And a good call it was. However I just wanted the full and accurate VIN info posted. There is indeed the 2 in the fourth position, and it is out of these 911T's that the 911 T/R models came. The 911R was a different beast from the 911 T/R. I won't try to explain all the errors in the Red Book.
Originally Posted by JJ 911SC View Post
As called earlier
The Red Book does not describe the "2 in the 4th position and it does not list; 11899001 to 11899020 ------ Coupe 911R but does mentioned that the 911R was a limited production run of light weight competition cars. Also refers to it as 911T/R
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 09-18-2012, 10:47 AM
83 911 Production Cab #10
JJ 911SC's Avatar
They all have errors.
Are your Database accessible somewhere?
Who Will Live... Will See
Old 09-18-2012, 12:02 PM
gearhead
If I had $5 for every mistake in that book, I might be able to retire.
One of these days I'll get around to cataloging all the engines and gearboxes and chassis I have here and send them over to you. I appreciate your efforts to document these things on our behalf.
1974 914 Bumble Bee
2009 Outback XT
Old 09-18-2012, 12:21 PM
To answer the original question (anybody remember that one?) I'd estimate around 40-42 cars per day.
JR
Old 09-18-2012, 01:25 PM
djpateman's Avatar
Thanks Matt, I would appreciate that.
JJ the database is not online since it contains a lot of confidential info. It is also pretty big and complicated so it does not lend itself to posting. However I try to assist where I can.
JR, I think your estimate is high; I count 7000 cars, and divided by about 240 working days per year it would come out to about 29 per day in 1968 model year for the 911 of which Karmann was making 3.4 per day.
Addicted since 1975
Old 09-18-2012, 02:10 PM
I was using 9802 cars. 240 days may be an accurate number; it also may be a little high, as it took 2 1/2 weeks, give or take, to build a car and there would have been some lag time to get things up and running after the factory holidays, I'd think.
Regardless of who built the bodies, they all used the same pool of engines, so I wasn't making any distinctions on where the bodies were built.
JR
Old 09-18-2012, 02:57 PM
JJ 911SC's Avatar
I understand and I know that you do help and provide excellent info as well as our friend from the EU.
Actually, I was surprise that every time I reply there was only me and the OP talking
I'm also surprise that the CoA seem to be spot on for a change...
Old 09-18-2012, 05:02 PM
