-   -   My front cooler setup is a failure! (http://forums.pelicanparts.com/porsche-911-technical-forum/70675-my-front-cooler-setup-failure.html)
widebody911 06-06-2002 01:51 PM
My front bumper cooler is a failure!
It was 105 degrees yesterday, and when driving a mix of freeway and surface streets, my oil temp rocketed to ~200!
This is unsufferable!
Early_S_Man 06-06-2002 02:03 PM
Better add a <b>Cool Collar</b> ... before you grenade that expensive engine!
Formerly Steve Wilkinson 06-06-2002 02:03 PM
You don't say what kind of front cooler you have. I installed one of the little airscoops that Wayne sells--goes in place of the bumper reflector on the right side--and it seems to work great. '83 SC, 28-tube cooler in the fenderwell.
sTephan
Tinker 06-06-2002 02:15 PM
Ya, what cooler are you running? 200 degrees in 105 heat is fine. My car gets up to 240 on the track in 95 degrees ambient when I am beating on it. That is with a cooler in the nose in one in the front fender. One the road/freeway is stays near 180-190. How about Jack's car with the twin coolers?
Tinker
john walker's workshop 06-06-2002 02:18 PM
i second the OK @ 200°. that's really good in fact, on a 105° day.
CamB 06-06-2002 02:21 PM
That is terrible Thom. All the way up to 200 and only on the street.
You know, this means you may see 210 one day...
... surely you can build it bigger again ;) Make it across the whole front of the car :eek:
(edit) I too am being sarcastic and am assuming that Thom is actually quite pleased with himself. 105F deg is something lik 37C, which is really frickin hot.
Don Wohlfarth 06-06-2002 02:29 PM
And what other kinds of fish did you catch today?
Pleez add ;) ;) ;) if you're fishin'.
At least no one asked if you were using water or antifreeze.
Wayne 962 06-06-2002 02:34 PM
Hello? Did anyone miss the fact that he said it was 105 degrees? Thermo laws dictate that the amount of cooling decreases as the temperature gradient decreases. 80 to 105 is a big 25 degree increase, and a big drop in the difference between the engine temperature and ambient air temperature.
Sounds like your oil cooler is working fine to me...
-Wayne
widebody911 06-06-2002 02:43 PM
My post was meant to be tongue in cheek - I definitely reeled in a couple! I'm quite happy with the temps.
I'm still hemmin' about getting the Elephant Lines, as mine have some flat spots. I see those flat spots and see extra cooling capacity.
makaio 06-06-2002 03:03 PM
Those Elaphant lines do look tasty! I must say i was way impressed when I saw them in person. I told Chuck, I almost wish, I needed new lines.
Bill Verburg 06-06-2002 03:07 PM
I agree with Warren, I think that you really need to get a cool collar to get the temp down to a safe 199
