1986 911 Carrera 3.2 leakdown and compression numbers
What numbers should I be looking for to determine a healthy engine during a PPI?
Thanks in advance.
Old 11-18-2016, 02:01 PM
Project Addicted
Exact compression pressures are hard to predict. Even pressures within a small range is what you look for. A proper test is done hot, throttle locked wide open, battery charger on and cranked until no more pressure increase.
Leakdown should be less than 10% at most. 5% would be real nice. Anything over 10% they should be listening to the intake, exhaust or oil fill to see if they can hear the air leakage.
These are just guideline and my .002
Good luck!
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 11-18-2016, 05:35 PM
ASE Master Tech - 35 yrs
larrym's Avatar
Arrow 911 cyl leakdown
Wayne sez:
A newly rebuilt engine should have leak-down percentages of around 3-5%. An engine in good running condition should show 10% or less. Numbers around 20% indicate some wear of the engine, but are still adequate for good engine operation. Leakage numbers of around 30% indicate that there are problems brewing,
Pelican Technical Article: Time to Rebuild? - Part II
buy the book - it will save ya a lot of grief
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 11-23-2016, 10:52 AM
85911's Avatar
For your reference, here's what I got on my 1985 911 last October with 67,353 miles. It runs great including at a DE, doesn't leak any oil, and starts right up.
compression:
#1- 175 psi
#2- 180
#3- 180
#4- 177
#5- 180
#6- 180
leak down test:
#1- 2.2%
#2- 0.0
#3- 2.2
#4- 3.3
#5- 1.1
#6- 2.2
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold
Old 11-23-2016, 12:48 PM
