| Registered Join Date: Mar 2001 Location: Marysville Wa.
				bugster
			well, i can't help myself, this project has been in my head too long. i nabbed this 63 convert at a vw swap meet last weekend. yesterday i stripped it down to what i need to work with. power will be a 911 engine mounted mid style and a 914 side shifter trans. it will have a tube frame, modified 911 front suspension with a shortened strut tube and custom upper A arms, and external tube shocks, double A arm rear suspension using the hub from a steel swing arm so 911 discs and e/brake can be used and a 4 link attached to the rear frame, which will be similar to a 906. the rear engine/trans/suspension area will be very open for that mechanical look. kind of dune buggy style. no fenders of course. the local RCW allows fenderless streetrods as long as it's not raining. the front wheel well cutouts will be smoothed with sheetmetal. can't wait to get started, maybe i'll close for a week.
				__________________ https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 08-25-2007 at 08:02 AM.. | ||
|  05-06-2002, 07:28 AM |
| Registered |
			Methinks it's good to be John Walker
				__________________ Dan Tolley 1987 911 Coupe The Owner's Gallery 2006 Audi A4 3.0q Cabriolet 2003 Ford F-150 XL Lumber and Trash Hauler. | ||
|  05-06-2002, 07:37 AM |
| Registered Join Date: Apr 2002 Location: Santa Clara, CA
			Very cool! Keep the pictures coming.
				__________________ Chuck Moreland - elephantracing.com - vonnen.com | ||
|  05-06-2002, 07:39 AM |
| Registered Join Date: Sep 1999 Location: San Diego
			what kind of 911 motor?
| Senior Member Join Date: Feb 2000 Location: Lacey, WA. USA
			WAY cool.
				__________________ Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" | ||
|  05-06-2002, 07:59 AM |
| Registered Join Date: Oct 2000 Location: Nor-Cal
			Bad A$$!
|  05-06-2002, 08:09 AM |
			the plan for the engine is a 2.0 with S pistons, solex cams, webers, and 914-6 headers. it will be so light that the 2.0 should push it along quite well. later on when i get used to it, a larger unit may get swapped in. with the limited fuel tank size, the 2.0 should have a decent range. not sure what wheels will eventually be used, just had these 993 ones sitting around. their negative offset may work fine, being there will be nothing for them to rub on, and will keep the track width more bug-like.
				__________________ https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 | ||
|  05-06-2002, 08:17 AM |
| Registered Join Date: Jan 2002 Location: West Lafayette Indiana
			It should now be clear what the difference is between art and rice.. Definitely bad ass.. Dennis H. 72 911E   | ||
|  05-06-2002, 08:32 AM |
| Registered |
			Nice Project!   How long will it take you to get it drivable, weeks,  months?
				__________________ John Adams 1980 ROW 911SC | ||
|  05-06-2002, 08:37 AM |
			hopefully i can get it dummy'd up in a couple of months for the annual 20 block long car show on the street in front of my shop. it may not be driveable by then, but should look cool at least.
				__________________ https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 05-06-2002 at 02:00 PM.. | ||
|  05-06-2002, 08:59 AM |
| Registered |
			I LIKE IT.... I LIKE IT ALLLLOT!   Jorge (Targa Dude)   | ||
|  05-06-2002, 09:00 AM |
| Registered Join Date: Apr 2001 Location: Marlboro NJ USA
			Wow! What a project.  Can you keep pictures coming as you go along? I for one would love to see documentation of what it takes to go from where you are now to a finished product. | ||
|  05-06-2002, 09:01 AM |
| Registered Join Date: Dec 2001 Location: South of Riverside Calif.
			I'm speechless... ok well i'm never speechless but man thats really got a cool look to it.  I can't wait to see it done! Will you be showing pix of it in progress?   I just picked up a poster from a German magizine of the early black fenderless bug/rod with a 6" chop thats been in a few mags lately. Its got a Ford straight axel pushed out front. so its got a nice look to it. Your convertible project takes that look to the limit and More! I think the wheels are perfect. Thats gunna be one unique machine.
|  05-06-2002, 10:16 AM |
| Registered Join Date: May 2001 Location: Glendale, AZ   USA
			I did a '64 VW Vert  2 years ago. Hereis the list of Pcar parts. H-4 headlights 914 front discs 911 rear discs w/ p-brake 911 seats 944 steering column 356 front beam with lowered spindles Boxster rims with z-rated tires 914 master cylinder Incredibly fun and expensive project for my daughter. I am going to try to post pictures, but I haven't had any luck so far. Let me know if there is something I am doing wrong. Alan Poh | ||
|  05-06-2002, 10:27 AM |
			See if this works.
|  05-06-2002, 11:40 AM |
			i put the picture in C drive, then drag it up on photoshop and cut it down to 6" wide, which usually falls within the 60K size needed to post. then write your post and then hit browse and find the pic in your C drive or whereever you put it, click it and it will come up in the browse window. post it and you're done.
|  05-06-2002, 11:55 AM |
| Registered |
			Sounds like a great project  ... sort of like a cross between Paul Newman's Beetle 'vert built by Jerry Eisert with a 351 Cleveland in front of a Hewland DG300 and indycar rear suspension ... and the Super Beetle 'vert of the mid/early '70s with the mid-engine 911 engine built by one of those German tuners.   Shouldn't have to weigh more than about 1900 lbs wet, and ought to fly with a 2.0 and about 140-150 hp on Solex cams. A banana sport-mufler with narrow oulets coming out the factory Beetle cutouts would be a nice touch!
				__________________ Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' | ||
|  05-06-2002, 12:18 PM |
			there was a super beetle built by a german guy named norbert or nordhoff, or something close to that, back in the 70s with a  mid engine 911. it would be interesting to see the technical drawings for that. mostly for the rear suspension setup. this car will probably not have any rear apron, decklid or rear wheel wells. it will be very open back there to show off the innands. it will probably have two big tailpipes though.
|  05-06-2002, 01:58 PM |
| one of gods prototypes |
			if you use the "attach multiple" option when replying to a thread it will let you upload a pic up to 100k. hope this helps
				__________________ Brought to you by Carl's Jr. | ||
|  05-06-2002, 03:37 PM |
| Senior Member Join Date: Jan 2001 Location: Left Coast, Canada
			John....Won't your Caddies be jealous of this latest creation?
				__________________ '81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. | ||
|  05-06-2002, 03:53 PM |
