Hello,
I just has a compression test run on a car that I am looking to buy, a 1988 911 with about 59k miles on it. The test compression came back with these numbers: Cylinder #1 160 psi #2 165 #3 165 #4 170 #5 165 #6 170 The guy told me that anything between 130 and 180 was very good. I have not done this before so I am not sure if this is true or what it "really" means. Any help is appreciated!
Brandon 1988 Porsche 911 Coupe http://www.tidalfish.com/bcw/porsche/pc.jpg If you like fishing, click below, you will love the site! Great boards like here! http://www.TidalFish.com |
Alter Ego Racing
You want to get more info than this, more meaningful is a leakdown test. Ask for one.
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion |
Your mech. is right
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Author of "101 Projects"
Didn't I already respond to this? What happeded to the all the posts? Did you delete this or edit it and then post again?
Strange... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Fish,
Glad you posted this question. Been meaning to ask about PPI results from my 911 purchase: #1 - 165 psi #2 - 155 #3 - 165 #4 - 165 #5 - 165 #6 - 170 Back then, the mechanic said compression-wise things looked "okay". |
160 in one and 145 in the other isn't necessarily bad, per se'. It's about 10% less, which is common with an engine that is getting older.
TedSlick, your numbers look okay too... -Wayne
Warren Hall Student
I did a test on my sisters 88' Nissan Stanza. She was woried about the condition of the motor since the car has 220k on the odometer. All four cylinders were within a half pound of each other and four pounds below "new" spec. I told her that that motor is going to outlive us before it needs a rebuild. Truth is that motor is never going to need a rebuild because it's going to end up in a junkyard because no one wants it anymore not because it wore out.
Bobby |
disband
thats a riveting story boboloo
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Forgot to ask the obvious follow-up question:
"Okay" PPI compression readings tells what about the engine? |
