-   -   trunk release handle broke (http://forums.pelicanparts.com/porsche-911-technical-forum/706981-trunk-release-handle-broke.html)
benzboy 09-19-2012 02:10 PM
on my 1973 911e, the trunk handle release broke. i really didnt have time to really look at it. but it seemed to break where the cable attaches. my question is how do i fix it?? feels like there is a couple of bolts on the bottom inside of the dash where the handles mounts. good thing the trunk lid want closed completely. any help would be great.
gamin 09-19-2012 02:53 PM
I assume that you have the trunk open. Detach wire from latch. It runs in a tube. Just pull it out one end or the other. Put in new one and attach. If you are lucky the screw at the latch may have become loose and the wire came out giving you the impression that it broke. If that is the case just reattach and tighten screw.
gamin 09-19-2012 02:58 PM
Cable available from pelican $10. It may only come out through the cabin.
benzboy 09-19-2012 03:02 PM
im sure the cable didnt break or come loose. the handle actually broke. the part that is attached to the cable. i tried pushing the cable up from the latch, like i would be pushing into the cable with no luck.
