Porsche Crest Steering wheel shaking
I noticed that my steering wheel starts shaking some from 65 to 75 MPH in my 1977 911.
It's fine below or above that speed.
Is this most likely a wheel or front-end issue?
Thank you
Old 09-19-2012, 10:43 AM
Undocumented User
McLaren-TAG's Avatar
Get your tires balanced first, it's the cheapest and best place to start.
Old 09-19-2012, 11:10 AM
Go-Kart Mozart
JAR0023's Avatar
Just went through this. Tires. My tires were at least five years old when I bought the car. Balanced, rotated, aligned when I purchased the car in May. Withing 5k miles the car developed a wicked shimmy between 69 and 74. It would fade out and come back around 85. It was kind of crazy as it would sometimes go away completely. I went through all the suspension pieces and found nothing out of place.
I had the tires road force balanced and they were pronounced good. Shimmy was still there. Replaced the tires with new RE-11s and car is smooth as a prom queen's thighs all the way to go to jail speeds. No other parts replaced.
J
Old 09-19-2012, 11:18 AM
SuperOldSchool's Avatar
'smooth as prom queen's thighs..'......thats awesome
1987 Triple Black Cabriolet - Wide Body
2011 Black Cadillac SRX
2007 Black Honda Element SC 5spd (for sale!)
2015 Yukon XL Denali
1966 VW Karmann Ghia
Old 09-19-2012, 12:50 PM
same here...balanced and wheel shimmy gone...well maybe just the slightest but I have all original parts up front so may not be totally a balance issue. The shimmy had gotten extremely bad before the balance.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 09-19-2012, 02:55 PM
dshepp806's Avatar
Tires,..first check on road-forced balancing....!
My car seems to be a bit sensitive to proper air pressures (especially when cold).
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-19-2012, 03:04 PM
like the other guys said. tires.
do those first- all of em.
save urself a bunch of headache
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 09-19-2012, 03:41 PM
Balancing the tires
Balancing the tires via the "road force balancing" method look like the place to start.
I think some of the Discount tire stores have the right machine. I going to check around tomorrow.
Thanks everyone for the feedback and help,
Ron
Old 09-19-2012, 06:21 PM
Go-Kart Mozart
JAR0023's Avatar
This could help you locate a Hunter Road Force balancer.
Hunter GSP9700 Wheel vibration Control System Locations
J
Old 09-19-2012, 07:11 PM
Air Cooled
Craig_D's Avatar
Take your 911, presumably with Fuchs, to a tire specialist familiar with older Porsches. There has to be a few in your area.
If you want your 30+ year old Porsche treated like a crappy civic and probably have the oil lines and rockers crushed on their lift, then by all means, find some discount tire store. But I wouldn't touch one of those places with a dead cat, much less my 911.
Just some advice..
Cheers, - CraigD
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 09-19-2012, 09:12 PM
muck-raker
kidrock's Avatar
Definitely have wheel balance checked, could also be a tire issue. Very common.
Talk to Jae (like "Jay") at Mirage, I think he's around Kearney Mesa. If he can't do it for you, he'll guide you in on the best source available. Awesome guy with awesome P-car knowledge.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-20-2012, 08:45 AM
Flat Six
Flat Six's Avatar
+1 for all tire/balancing/pressure above, and one additional item to consider: How often do you drive? I find that if I let the car sit a week or more the tires will flat-spot a little and resonate at speed. For me, takes +/- an hour of driving for them to 'round out' again.
Tire (re-)balance won't help the flat-spotting issue.
Yet another reason to drive it all the time.
HTH
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 09-20-2012, 09:05 AM
djk_wff's Avatar
Usually my '88 3.2 carrera steering wheel shaking (shimmy), is a reminder that it is time for a valve adjustment!
1988 Porsche Carrera 3.2
Triple Black
Old 09-20-2012, 09:20 AM
yup what CraigD said. on my last tire purchase i went to discount tire- let me just say i do all the the work on this car and it very rarely sees a shop- that being said i decided to stroll out to the work area to check on the car. i was just in time to catch the gorilla roll a jack under the car without looking and begin to crank on that thing like he was mad at it. i got him to stop right in time and asked him what he was thinking, he had no answer. so point being be VERY carefull who u let touch ur 911
Jason
81 SC
97 328is
Old 09-20-2012, 09:46 AM
dshepp806's Avatar
valve adjustment? WTF?
Doyle
Middle Georgia
Old 09-20-2012, 03:49 PM
Uneven tire wear. I had exactly the same problem. New tires and balance. No more shake / vibration.
Old 09-20-2012, 04:59 PM
porwolf's Avatar
Had a similar problem in the rear of my Landcruiser once. It turened out to be internal damage to one of the tires that must have created a small bump. After a while the rear tire exploded on the freeway at 70MPH and tore to shreds. I was lucky that it was in the rear and only caused body damage. I could still go straight onto an off ramp and change the tire.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-20-2012, 11:52 PM
donagain1's Avatar
I'm still thinking about the prom...
Old 09-22-2012, 04:04 PM
If balancing the tires doesn't help then you may want to check your tie rods. I had steering wheel shaking at certain speeds and solved it by installing new (turbo) tie rods.
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
Old 09-23-2012, 06:32 AM
