Virginia Rocks!
VaSteve's Avatar
Removing the front valence?
I want to remove the accordions on my car so that I could clean and detail it all and put it back together. I was able to get the driver's side off without too much drama (still a bit a of challenge), but on the passenger side there is a bracket in place that will make it impossible...see photo. I assume that this has to do with the fender oil cooler. Thus, I don't think I can take this apart without taking off the valance.
Can someone describe where all the bolts are? Or better, anyone have photos of the valance/bumper removed? I've seen millions of photos like that over the years, can't find any today.
Finally, I'd like to remove (maybe) the rubber strip on the front bumper. How does that come off? I assume there's some bolts behind the bumper?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 09-23-2012, 09:00 AM
This can be done! I just spent the morning doing it and it can be done....with patience. Try to avoid removing the valence as it is tough to re-install!
Marvin
1986 944 Racecar
2000 Boxster ClubSport
Old 09-23-2012, 10:29 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
oh goodie! i can contribute here...i found that is actually much easier to go ahead and remove the whole front bumper with the valence still attached...then further disassemble if desired.
The opposite order for reinstall. The valence hardware probably needs replacement by this time anyway...or your can just clean it up and rattle can it.
It can be done in the order mentioned above, but you'll need alot of patience and a ratcheting box end wrench for one or more bolts on that passenger side.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 09-23-2012, 10:51 AM
hold out for pics, but you can start by sliding the rubber strip on the very front of the car to either side to remove it. behind it are large hex bolts where the impact shocks are attached, this is what holds the bumper on, along with 4 small screws on each side where the valence meets the fender.
Old 09-23-2012, 10:55 AM
Virginia Rocks!
VaSteve's Avatar
I ended up taking the bumper off and leaving the valence in place using this thread:
'88 911 Bumper Removal
Will have my own photos to post later.
Old 09-23-2012, 01:23 PM
